CL-Class (W215) 2000-2006: CL 500, CL 600
P/S fluid
Old Mar 9, 2009 | 09:49 PM
droc112's Avatar
cl600
P/S fluid
does anyone know how many cans of pentosin it takes to fill up the hydrolic resovoir i have a 02 cl600? my driver side is sitting low but my passenger side is ok i already know that my pump is leaking but i wanna know if i feel up the resovor will my car raise up i need to get it towed to the dealer????
Old Mar 10, 2009 | 11:46 AM
~CL500~'s Avatar
E90 N54 & W251
There are 2 reservoirs, one for the ABC and the other for the PS. They both go to the same pump (tandem pump) and are both the same fluid:
ABC Hydraulic Fluid (Pentosin CHF 11S) - Q 1 32 0001
When you pull the dipstick out for each, there is a level indicator for engine off and on. Make sure you're within those limits of each.
Regarding quantities, I would buy 1 can and go from there. You're not filling up the whole system, just the reservoirs. This fluid is close to $40 a can.
I highly recommend that you get the leak fixed. Topping off ABC fluid is no solution as the uneven dip may be from another problem. Good luck
