CL-Class (W215) 2000-2006: CL 500, CL 600
taking care of your ABC
Old Jun 25, 2009 | 09:41 PM
Ifari's Avatar
2000 CL500 1992 300SE
Originally Posted by wease206
ABC valve block (rear by the passenger side) is leaking a little fluid part cost 791 whole sale price 591 labor is 400. is there a better way to fix this or this is the only way ( by replace the unit). Also the filter is only to be change if it need to be change that what they inform me about becuase the filter play with the power steering pump, even if the ABC line connect is that true?
Check the O-ring on the ABC pressure sensor on the valve block which has the leak. If the leak is at the O-ring, buy an ABC system pressure sensor kit at the dealer. It will contain an O-ring and a metal guide to aid installation. It's far less expensive than having to change the valve block and just may solve your problem.
Old Jun 27, 2009 | 01:57 AM
wease206's Avatar
W215/X164/C124
did a system check again it was leaking from the unit
1044 total
Old Jun 27, 2009 | 02:52 PM
Ifari's Avatar
1044 total
Part and labour? Break it down for me pls. How is the car now?
Old Jul 1, 2009 | 03:19 AM
wease206's Avatar
W215/X164/C124
labor 377
parts 683
they also bleed the system and ran the rodeo
very funny to see how the rodeo works
car run better when i hit a bump it is more smoother
thank last time
