Tire Wear
CL500
Tire Wear
Do u guys get a lot of tire wear on the inside of ur back tires. my tires last 10K with regular driving and i have dot the ilignement done several times to no help.
2004 CL55
car lowered? That wear should be more even, but its common on lowered cars due to negative camber. I have just a bit of negative camber (lowere 1.5 inches) and my tires do wear down on the inside first, but even then it is no less than every 20K miles. 10K is pretty fast!
CL500
CLK63 BS
CL500
i cant rotate them because the back wheels are wider, i guess i will take it the the MB dealer and we will see what happens.
Formerly W215 CL600
Uneven tire wear is unacceptable regardless if you have stock tires or not. Inside wear on the rear can be diagnosed easily at the dealership. My rear alignment was off, I cannot rotate my tires either. They are staggered. 295/30 on the back and 255/35 front 20". To get it re aligned is so inexpensive considering the cost of new tires. I now have even wear. It may not be this on your car, but you need to get it looked at by a professional.
![](https://mbworld.org/forums/attachments/cl-class-w215/151401d1236394903-new-owner-2003-cl600-dsc03594.jpg)
CLK63 BS
CL500
well i took it to the dealer and they said that they couldnt do anything about the tires, when u sit behind the car u can see that the back tires r slanted and the MB guy said that the only thing that they can adjust is the tire from left to right and not up and down. if this is the case i would always get wear on the inside.
