CL-Class (W215) 2000-2006: CL 500, CL 600
Winter Storing??
Old Oct 23, 2009 | 02:23 AM
geewai80's Avatar
2003 CL55 AMG
Winter Storing??
Hey all,
Does anybody know how to properly store a 2003 w215??? I'm planning to store the car over the winter months and want to do it properly.
Any help would be great
Old Oct 23, 2009 | 09:32 AM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Originally Posted by geewai80
Hey all,
Having a car sit for a few months is no big deal. If the oil is fresh, I would just park it in the garage and disconnect the battery. If the oil is not fairly new, I change it and the filter. Washing and waxing is also not a bad idea. When putting it back on the road, be sure the battery is fully charged. BTW, the suspension will probably drop after a couple of weeks which is normal on the CL. It should raise after restart.
Old Oct 23, 2009 | 10:08 AM
slonar21's Avatar
CL600 2003
I think you should keep the battery plugged and use a good trickle charger (CTEK). If not, all your windows and other electrical devices will be screwed up...
Old Oct 23, 2009 | 11:09 AM
Jud Chapin's Avatar
There is a simple sequence for battery resynchronization after battery reconnect as follows:
1) Windows-hold each window switch down 1 second after window is closed.
2) Moon roof-Press switch raising roof rear; hold for 1 second.
3) ESP-Turn steering wheel full left, then full right.
I don't like keeping a battery under charge over night...had a neighbor burn his garage up doing so.
