tpms sensor 0008223406 (replacement)
I have 04 cl500
I gotta change all 4 tpms sensor because the battery is low in one them.
Where is the best place to buy oem tpms sensor?
Do i need to take to mercedes dealer for programming?
Thanks for any advice.
Are you in the States? If 'yes', you can call Lee at 888-981-3953 ext 623 to order. 4 sensors and 4 valves (required) cost around $400 shipped. You can reset them via the display, no dealer required.
How do I activate them via the display? I have them on my winter wheels but not my lowpros cause the tire is too stretched lol..but when I put my winters on here in a few days I want to have the TPMS running
Well we couldn't get the tire over the thing in the first place, yes it was in the middle and yes I even had an aftermarket adapter. If we had gotten the tire over it without breaking the stem...then it would've been sitting on the rubber (inside) which I don't think would go over well with potholes ..who knows, doesn't bother me much
I would repair them too. I have bent two of my Brabus rims and there are plenty of shops the deal with bent rims, especially now that we have so many 3 ton sport utes driving around with low profile tires. should be between $100-$200 per.
Not sure if it's the same on 2002 CL500. Use the button on the left of the steering to move to TPMS screen. Press the "R" on the right side of your instrument. The screen will pop up a question if you want to re-activate your TPMS. Use the button on the right of the steering to change it from N to Y. If nothing else is wrong, it should show the correct reading in several minutes of driving. Good luck
