CL-Class (W215) 2000-2006: CL 500, CL 600
Help with CL500 Staggered Wheels setup
Old Dec 12, 2009 | 01:58 PM
mycl500's Avatar
CL500
Question Help with CL500 Staggered Wheels setup
Am I going to have issues with the rear 275/35-19 with an offset of 47mm? Is it going to rub the fender? Will I need to get the fender roll? You know of any place in Seattle/Tacoma that would roll the fender? Thx for any feedbacks.
I'm planning going with this setup:
Front Fitment
19x8.5
Offset: 46mm Backspacing: 6.61" Bolt Pattern: 5-112
Rec. Tire Size: 245/40-19
Weight: 31.5lbs.
Important Notes
Optional Rear Fitment
19x9.5
Offset: 47mm Backspacing: 7.12" Bolt Pattern: 5-112
Rec. Tire Size: 275/35-19
Weight: 32.0lbs.
Old Dec 12, 2009 | 07:16 PM
slonar21's Avatar
CL600 2003
I think you will be fine, check this link for wheel fitment...
http://www.alloywheelsdirect.net/inf.../mercedes-benz
Old Dec 13, 2009 | 12:33 PM
fatmike's Avatar
CLK63 BS
You'll be fine
Old Dec 13, 2009 | 04:39 PM
wease206's Avatar
W215/X164/C124
21x9 255/30R21 21x10.5 285/30R21 Brabus
would this fit
Old Dec 13, 2009 | 09:31 PM
slonar21's Avatar
CL600 2003
I don't think so, with 20's the max would be 255/35/20 and 285/30/20 and brabus recomends rolling fenders with this setup. If you want 21's you will need a thiner tire like 255/30/21 and 285/25/21. The car will handle very rough, I would not go bigger than 20". You can always call up Brabus, they are always willing to help with there products.
Old Dec 14, 2009 | 02:17 PM
Patentmat's Avatar
Just so the record is not wrong for people searching this thread in the future, I believe the max is 305/30 on the 20s as I have not seen anything wider, and that is what I am running. Mine is the 55 so the fenders are already rolled. I completely agree with slonar21 though, on not going larger than 20s. Maybe on the new body style but not the 215.
Old Dec 14, 2009 | 04:53 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
You may check it on this website :
http://www.bigcustomwheels.com/info_specs.jsp
Just put your original size on a left side and optional on a right.
It will tell you result at the bottom.
GL.
