CL-Class (W215) 2000-2006: CL 500, CL 600
Fuel Injector
Old Dec 30, 2009 | 05:47 PM
CoupeLeicht600's Avatar
Yes!
Fuel Injector
Do I need to have it cleaned? If so, in about how many miles?
Old Dec 30, 2009 | 08:29 PM
jaime's Avatar
SLK 350 DESIGNO 2007 SILVER/BLACK-MISTIC RED
I HAVE THE SAME QUESTION.... OF COURSE, THEY ARE NEEDED TO BE CLEANED, BUT I DO NOT KNOW HOW OFTEN.
Old Dec 31, 2009 | 10:17 AM
StarPower's Avatar
2003 Lincoln LS V8
I don't know what the recommendation is, so I can only give you my experience. I had mine cleaned at ~48,000 mi, and it really smoothed out the idle. I suspect quality of gas (detergents) has a lot to do with it.
Old Jan 1, 2010 | 01:07 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Unless MB has different types of injectors than those of American engineering, they shouldn't have to be cleaned unless their is a specific problem with them. I have never had injectors cleaned on any of my cars and they all ran great. I had an '84 Vette with over 200k on the odometer, and now have a '91 Lincoln with 175K on it and my daughter has a '97 Jeep with 275K on it. I've never had those in my '02 CL500 cleaned although it has just 35K on it. I think when injectors first came out, gasoline was not ready for them and caused them to need cleaning. Today's fuels contain additives that do the cleaning. Just my 2 cents on the subject.
Old Jan 3, 2010 | 11:52 PM
Yes!
Jud Chapin
Thanks Jud. I didn't realize that. I was thinking that my fuel injector needed to be replaced because of the constant check engine light. I figured maybe that I was getting bad gasoline at the local gas stations despite it being a 93 anti-knock rating. I'm debating on changing it, but your input definitely helps me reconsider.
Old Jan 4, 2010 | 08:46 AM
Jud Chapin's Avatar
I would have the check engine light diagnosed before replacing any parts. Have a tech pull the fault code(s) to determine the problem and go from there.
