what set up do i need to get a good drop on my 2002 cl500
what set up do i need to get a good drop on my 2002 cl500. Right now im running a set of staggered zenneti heirs 35+ offset -10 x 20 (rear) with 275/35/20 & 245/35/20 -8.5x20 (front)...and i just ordered some links but when i looked in the front wheels wells the control arm is pretty close to the tire already...do i need spacers? any help would be appreciated....
Wrong. Buy adustable links from www.adjustableairride.com
They si exactly like the original "arms". Lets you easy lower it how much you want/can...
Done it myself with the same setup
Sorry I am kinda new to these cars, I thought that was the only option.
By the way the electronic module goes for around 100EUR sometimes on Ebay.de so if it were me I'd go for that option.
EDIT: I tried to find the lowering module and it looks like it is actually what they are also selling in the shop linked above...
David
David
David
David
In my edit you can see that I wrote that the ones if found on ebay.de most likely were adjustable links and not a electronic lowering module, here are the link to the auktion, also check out the link below to a cheap used electronic lowering module.
http://cgi.ebay.de/Mercedes-Benz-Tie...item20aebdabd9
Only one day left:::::!
http://cgi.ebay.de/ws/eBayISAPI.dll?...=STRK:MEWAX:IT
