CL-Class (W215) 2000-2006: CL 500, CL 600
alternator replacement
Old Jan 11, 2010 | 12:57 PM
wease206's Avatar
W215/X164/C124
has anyone ever replace the alternator yourself
my alternator is giving up i order a new one already
Old Jan 11, 2010 | 03:58 PM
Jud Chapin's Avatar
'16 S550 Coupe, '11 Lexus LS460, '02 CL500 (SOLD)
Wease, I thought you had the Star Service Manual Library for the W215. This DVD shows how to swap it out among many other jobs. If you don't have it, yu can order it by calling MB at 800 for-merc. Good luck.
Old Jan 12, 2010 | 03:08 AM
wease206's Avatar
W215/X164/C124
I do have but it but the DVD software support windows XP I have windows 7
I guess I'm going to order a new one
Old Jan 12, 2010 | 03:21 AM
wease206's Avatar
W215/X164/C124
i do have it but it does not support windows 7 it only support windows XP
Old Jan 12, 2010 | 12:10 PM
Ifari's Avatar
2000 CL500 1992 300SE
The job of removing the alternator should be straight forward.
You will have to remove all the nearby components, such as the windshield washer reservoir, air pump, fan shroud, v-belt and nearby pipes, hoses, electrical connectors and cables in order to easily access the alternator.
Then remove the 3 bolts holding the alternator in place and remove. You may want to inspect the flange gasket at this time.
Install in reverse order and then re-connect the other components.
Old Jan 13, 2010 | 06:12 PM
wease206's Avatar
W215/X164/C124
flange gasket WHERE IS THAT LOCATED AT AND WHAT IS IT?
Old Jan 14, 2010 | 09:43 AM
Ifari's Avatar
The flange is the rim piece that the alternator is attached to. It will have the bored holes in it and the gasket rests on the flange before re-installing the alternator.
Old Jan 14, 2010 | 05:11 PM
wease206's Avatar
W215/X164/C124
CAN YOU POST UP SOME PICTURE AND MY A CHANCE DO YOU HAVE THE MB PARTS NUMBER. I CALL THE MB STEALER THEY DONT KNOW WHAT IM TALKING ABOUT
Old Jan 15, 2010 | 04:33 PM
Ifari's Avatar
If they don't know...don't worry about it...also, if after removing the alternator and you have a gasket, you can show it to them.
Old Jan 15, 2010 | 06:56 PM
wease206's Avatar
W215/X164/C124
how does the gasket like
Old Jan 15, 2010 | 09:58 PM
Ifari's Avatar
The gasket will be a piece of fibreboard that is shaped like the alternator flange.
Old Jan 16, 2010 | 02:33 AM
wease206's Avatar
W215/X164/C124
is that flange the by the pully or the back side where the wire hook up
Old Jan 16, 2010 | 02:23 PM
Ifari's Avatar
The flange with the alternator attached to it.
Old Jan 17, 2010 | 03:41 PM
wease206's Avatar
W215/X164/C124
the front or the back of the alternator here is picture that i have
Old Jan 17, 2010 | 10:25 PM
Ifari's Avatar
There is only ONE flange for the alternator.
It is on the engine block for the back end of the alternator to be bolted to.
The gasket is for the 600 engine, so don't worry about it.
Old Jan 17, 2010 | 11:06 PM
wease206's Avatar
W215/X164/C124
please circle the part of the flange or
email. me just want know for future knowledge in casw i want to buy a 600
Attached Thumbnails alternator replacement-b.jpg   alternator replacement-bosch.jpg
Old Jan 18, 2010 | 09:49 AM
Ifari's Avatar
You're welcome!
