oil filter how to install
i never change my oil in my life because im a lazy person
today i just made a move to change that
i bought the oil filter today from the stealer which way does it goes in
there two line on it
It can go either way, just make sure it's all the way up. There should be a small pictured instruction paper in the box indicating you should only see one line when properly installed. Be sure to change all the o-rings.
2003 CL500, 2006 ML500
oil filter change
hey, when I changed the oil filter I could only locate 3 O rings (2003 cl500) but on the filter came with 4...am I missing one?
there is a very small one at the bottom of the filter assembly, then a medium sized one a little higher up and a large one around the housing cap.
please give me your advice.
thanks!
thanks!
thanks!
thanks!
