Help! Keyless go, just doesn't work?
hi, my CL500 AMG 2005 has another problem.
The keyless go is completely knackered, both keys work eg.unlockdoors/boot and starts car by putting in the ignition thing.
BUT is doesn't work as in 'keyless go' the car wont open by leaving the key in pocket and the car wont start by the gear selector switch basicly its like the car doesn't know any of the keys.
I checked it out at mercedes benz and they said its the whole computer that handles that part and the car just doesn't recognise the keys and would cost £500 just for that part.
does anyone know if theirs anything else that might help it?
What do you mean do switch?
Btw i checked the fuse and replaced it, but nothings happening the car dosnt even say anything on the display eg Key not recognised. so basicly its just like the car hasn't got keyless go so if anyone has got an idea plz tell me otherwise its going to merc for a new part thats £700 and thats just that part?
Thanks.
Thanks.
hi
i had similiar problem: keyless go not working, even the door did not open using remote buttons...got wrong almost 4 out of 5 times. but once in, usually the gear start button would work, then that stopped working too..though ignition was still working.
I replaced battery...no improvement.
Then idea struck and i found the simple problem and solution: the battery holder was loose!!! so put a small piece of paper to tighten the battery holding and viola .....3rd day and im happy with my keyless go...
BTW i read some post saying put the key in ignition for an hour and it will reprogram itself...i tried that but after 10 minutes realised it is non sense and stopped...(this was before finding the solution above)
s350 - 2005 - 57,000KM
Thanks.
Thanks.
1 Post
2005 SL55 amg, 2009 Lincoln MXZ, 2012 Dodge 2500 Limited
i have two key fobs but only one works for the keyless go? replaced the battery in fob and still no go? think i may have a defective fob? is there away to check if fob works?
Turn your mobile or other camera On and put the fob pointed end under this and press fob button. If U see light in camera fom the fob the fob is probably ok.
Does it work other than keyless go i mean if you just press buttons on fob does it oPen the door?
Btw Did u try tightening the battery holder?
I had exactly the same problem. In the end I found that the key was not linked to the car. I only found this out by using STAR. Through STAR you can marry the two up. Bingo. I now have keyless go.
Alanb
Alanb
