Radiator Hose for Cl 600
2020 GT R Pro
Help..... I need a radiator hose for my CL 600 2002. Mercedes does not stock or make the hose any more. Hard to custom make..... any ideas?
The hose actually connects to the bottom of the resevoir and than to the heater and bottom of motor. Fitted hose
2020 GT R Pro
I wish I was wrong. I had it confirmed by 3 dealers on the east coast, west and north. The hose that comes out of the resevior to the heater and bottom of motor. I had to make up a hose from NAPA. It works but I am not to happy with it. I had to use part of the old hose to make it work. Germany is no longer making that hose. After 8 years they are not required to.
I find this hard to believe also. Try calling MB USA in NJ at 800 for-merc. ask for the tech dept and advise them of your problem.
Try this link, number 3 part down the list should be the one you are looking for:
http://www.germanimportedparts.com/c...0-137.970.html
David
David
2020 GT R Pro
David
David
Go to this site, select Mercedes and follow the prompts. You will be able to get a part # here and give it to your MB parts dept or call MB as I suggested above.
http://www.detali.ru/priceInfo.aspx?code=gmbA1120940004
2020 GT R Pro
Here's your hose, p/n 220 501 22 82
http://www.trademotion.com/partlocat...layCatalogid=0
Go to the second CL600 listing in the parts listing site I sent you above. Your hose is listed with its part no.
![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2020 GT R Pro
Go to the second CL600 listing in the parts listing site I sent you above. Your hose is listed with its part no.![drive](https://mbworld.org/forums/images/smilies/driving.gif)
2020 GT R Pro
Mercedes found this also hard to believe. They had to research and call back, but they found the answer. The one hose that is not available is now replaced by 2 hoses part number 220 501 48 82 and 220 832 37 94 they could not believe it but the dealers totally missed it. Thanks. Now I know why there is a plug below my oil cooler line in the radiator. That plug is for the new hose. I would like to know the reason for this change and difference from this simple engineering change for the reservior heater exchange hose.
