CL-Class (W215) 2000-2006: CL 500, CL 600
Help with OBD II Codes Please
Old Apr 19, 2010 | 10:41 AM
paul65k's Avatar
2016 E250 Bluetec 2002 CL55, 2000 430CLK Cab
Hi Guys,
Had the dreaded "Check Engine" light come on late Friday night for the first time. I bought an OBD II reader today (Costco $20) and checked the codes and here's what I got;
1. P0400 - Exhaust Gas Recirc - Flow Malfunction
2. P0105 - Manifold Absolute Pressure (BAR), Pressure Sensor Circuit
Is #1 an ERG valve replacement? No clue what #2 would be or if this is just a by-product of the first. I haven't driven the car since resetting the error codes and while I did restart the engine the "Check Engine" light did not come back on. Is it likely that this could have been a spurious error code or could this be shades of something bigger to come??
My car is an 02 model without Kompressor and has ~74K miles. I am covered under a Chrysler Maximum Care Warranty so if this is something that would e covered I'll certainly have the work done at the dealer but if this is considered a maintenance item I'll likely have my local indy take care of it.
I would definitely appreciate any insight some of the more technical guys here might have if you wouldn't mind.
Regards,
Paul
