CL-Class (W215) 2000-2006: CL 500, CL 600
HELP 2004 Cl500 Trans problem
Old Jun 19, 2010 | 07:29 PM
blkS55's Avatar
07 335i, 04 Cl500
Hey My 2004 C500 with 26k miles on it is having some problems..
1st of all this has happened twice, the car would get stuck in 2nd gear In D Mode and not shift at all, it would go past Redline.
The 2nd problem is at high Rpms near 5-6 there is a loud whine sound before the car shifts gears..
Has anyone had any problems like these, the car is CPO so hopefully it will all be covered if there is a problem
Old Jul 1, 2010 | 12:18 PM
3ktt's Avatar
gl550
cpo with take care of it, just take it o the dealer
Old Jul 2, 2010 | 02:57 AM
blkS55's Avatar
07 335i, 04 Cl500
yes they did..
The valve body had to be replaced
Old Jul 26, 2010 | 11:29 AM
kataboboi's Avatar
Mercedes
can anyone tell me what is all need to be replace to make the car work correctly...
Old Jul 26, 2010 | 03:09 PM
~CL500~'s Avatar
E90 N54 & W251
For anybody else out of warranty with this kind of issue, this is the valve body and conductor plate sold as a single unit. A broken spring in the valve body causes the issues mentioned above.
Never dealt with this company before, but seems like a cost effective option:
http://europeantransmissionscom.x-sh...cat=715&page=1
Old Jul 26, 2010 | 03:23 PM
kataboboi's Avatar
Mercedes
Thanks for the help but is there a way we get a picture of where its located under the hood.
Old Jul 26, 2010 | 03:32 PM
~CL500~'s Avatar
E90 N54 & W251
This can be found when you drop the transmission pan. The transmission filter hangs off of the valve body. The picture you see faces up towards the cabin. The top left is the infamous plug adapter that that has leaky O rings.
Old Jul 26, 2010 | 03:48 PM
kataboboi's Avatar
Mercedes
would this be the main reason why its stunk on 1st grear in D mode. also the speedometer stop working when that happen ????
Old Jul 26, 2010 | 04:02 PM
~CL500~'s Avatar
E90 N54 & W251
Not sure as each car should be looked at case by case. Also, it would be prudent to check the transmission with a Star SDS system for specific codes before forking out any cash for parts. Good luck!
Old Jul 26, 2010 | 04:11 PM
kataboboi's Avatar
Mercedes
Thanks,,,
Old Jul 26, 2010 | 04:20 PM
saintz's Avatar
GL450
Did you spill anything on the shifter?
Old Jul 26, 2010 | 05:09 PM
kataboboi's Avatar
Mercedes
No I don't think so. why ????
Old Jul 31, 2012 | 01:22 PM
koolaid1013's Avatar
2004 CL 500
trans..problem
when I put the car in gear ..sometimes I get no response..until I go back to PARK....then car responded.Then one time...it seems as though the tranny was slipping.
Old Jul 31, 2012 | 07:58 PM
biker349's Avatar
cl600
when did you do a filter and fluid change?
Old Aug 3, 2012 | 03:54 PM
2004 CL 500
I was told...that was done already.I bought the car recently...all of these things was suppose to been done...
Old Aug 3, 2012 | 07:16 PM
biker349's Avatar
cl600
you need to know for sure when fluid was changed. burnt, dirty fluid could cause problems. at the least check the fluid color to make sure it's a nice red color.
