Pothole - 1 Cracked Rim/Tire, Check Engine Light, and Headlight Flickers, Vibrations
I pulled over and noticed a bend and a crack in the rim and a flat tire (19" AMG's), while waiting for the tow truck to arrive. I got the CL home after waiting almost 2 hours for a tow and proceeded to install a different set of rims thinking that was all that was needed, boy was I wrong. After installing the different set i took it for a test drive and noticed my left headlight turning on and off by itself.. and it doesnt seem to be aimed properly,wonderful I thought to myself... then minutes later the Check Engine Light proceeded to come on. looool
I had the codes ran at my local auto parts store and it's reading the O2 Sensors are having issues indicating an exhaust leak... the car is driving normally and the final test was taking it on the highway when I took it a little past 70 mph and noticed a slight vibration and when you apply the brakes the pedal now vibrates.
I'm at a loss for words here, I called CDOT and filed a complaint and a claim with them and my insurance as well. I am not going to let these guys go until the the CL is 100% again. Just in time for better weather and the CL is out... makes me so sad. A few questions i had are; what should I be checking for damages from the described and how do i go about making sure the suspensions is working properly? any comments and suggestions are welcomed!
