CL-Class (W215) 2000-2006: CL 500, CL 600
what is this for...?
Old Feb 25, 2011 | 05:15 AM
mercedesauto's Avatar
2006 CL600, 2006 SL65
hello everyone,
i will try to upload the picture below, and i need to know what is the cap for (marked in red circle)...?
what is inside (water, coolant, hydraulic, etc)...?
how i check that (the level)...?
any info will be appreciated...
thanks
Old Feb 25, 2011 | 06:06 AM
saintz's Avatar
GL450
I believe that's the radiator cap (one of them) for the coolant system, which is used to cool the intercoolers. You can check the level in the main coolant tank (passenger side, closer to the front).
Old Feb 26, 2011 | 03:33 AM
hello saintz and thanks for your reply...
did you mean it is a separate cooling system for turbos or it is connected to vehicle's main cooling system (if so, why would they put another cap under the cover?)...
Old Feb 26, 2011 | 12:59 PM
saintz's Avatar
GL450
The main cooling system is used to cool the intercoolers for the turbo. It's a water to air intercooler. There is a pressure cap by the radiator, which can be used to bleed pressure, bleed air, or top up the system. The pressure cap up there is presumably for the same reasons. If the intercooler gets too hot, having a second relief valve there would help.
