CL-Class (W215) 2000-2006: CL 500, CL 600
driver side window problems
Old May 29, 2011 | 09:31 AM
Thetoz's Avatar
2003 CL55amg
I have a problem with the driver side windows. When the door is opened, the front and rear windows drop down for the door to be opened, but they don't pop back up when the door is shut. You either have to shut the door several times, or manually raise the windows. The problem is intermittent, sometimes works ok, other-times not.
Has anyone else had this problem, and can offer any advice? Went to a local shop, they hooked up a computer to the system, but they couldn't replicate the problem.
I greatly appreciate any help.
Old May 29, 2011 | 04:29 PM
biker349's Avatar
cl600
try holding the button in the up position for 3- 5 seconds after window is fully up. let us know if that helps and resets the system.
