CL-Class (W215) 2000-2006: CL 500, CL 600
How to Remove Passenger Rear Interior Panel
Old Jun 6, 2011 | 06:41 PM
superfast's Avatar
97 Lexus LS400, 04 Mustang, 08 Corvette Z51, 92 Honda Civic Si, 02 CL500, 03 E500
I need to get access to the passenger rear window regulator on my 02 CL500 (rear window not working). Can someone show me how to remove the rear interior panel? Thank you so much in advance.
Old May 8, 2013 | 08:01 PM
LoneWlf794's Avatar
1995 Ford Ranger
Per service information, if you need more detailed information on any step let me know.
1.1 Remove rear seat backrest (Only when side airbag is present in rear)
1.2 Remove rear seat cushion
2 Remove door sill molding (1)
3 Remove chrome plated molding (2)
4 Remove edge guard from door frame
5 Remove cover (4) from handle recess (5)
6 Unscrew screw (6) and remove handle recess (5)
7 Unscrew screws (7), 2 each
8 Unscrew bottom screw (8)
9 Unscrew nuts (9) (Only when side airbag is present in rear)
10 Remove side wall paneling (10)
11 Install in reverse order
Attached Thumbnails How to Remove Passenger Rear Interior Panel-untitled-2.jpg
Old Feb 23, 2018 | 01:36 PM
firstCL500's Avatar
2001 CL500
Awesome write up, but each step (for a newbie like me) isn't detailed enough to understand the "how". It's always easy to ask others to do work, but if you could post a pic for each step number with your finger pointing at the area of "release" and the tool needed, I bet even I could tackle the fffd up window on my CL. Thanks for posting even if you don't have the time to expand. I love that folks on this site help others. These are really freaking cool cars, but stupid expensive (to repair at the dealer) and complicated. The help is appreciated more than you likely know. I'm down to RR window, intermittent ABC light (haven't seen it in a week), removing L side mirror glass and cleaning, replacing the trunk motor or whatever is failing, fixing the washer reservoir leak, and replacing the seals on both side mirrors. I do those things and I'll be driving a very, very sweet car!
Old Feb 24, 2018 | 03:31 AM
tusabes's Avatar
Mercedes
this is a 4 year old thread , no info is gong to post a step by step pointing at parts as they disassemble their car for you . I hope you were joking
as for the intermittent abc light of it happens when driving over bumps it's your accumulators
