CL-Class (W215) 2000-2006: CL 500, CL 600
yet another weird trouble
Old Jul 23, 2011 | 02:54 PM
alex-300te's Avatar
1989 300te
Hi guys, just got one of the real valves replaced on my cl500, now the car develop a weird condition power steering fluid is bubling in reservoir coming out cap pin hole breather any toughs? I been adding 200cc of fluid every 3 days and is making my a mess by the reservoir, is only coming out by breather all ready look for leaks every where and no leaks where found, car rises and drop as should and not drop over time, no codes
Old Jul 23, 2011 | 02:58 PM
alex-300te's Avatar
1989 300te
Car is 2002 cl500 47' milles on it
Old Jul 23, 2011 | 03:00 PM
alex-300te's Avatar
1989 300te
Car is 2002 cl500 47'k milles on it
Old Jul 23, 2011 | 04:26 PM
slonar21's Avatar
CL600 2003
Here you go, this might help
http://www.benzworld.org/forums/w215...d-seeping.html
This is a quote from that forum about the fix:
"Well, I just got my car back from the shop (indy), and it works great.
Here's why,
Replaced the tandem pump with a new Luk pump
Replaced the valve block/accumulator
Replaced the filter
Flushed system
Filled with fresh Hyd fluid
Cost $2,749.00 total
Suspension works great, and no noise at all!! "
Old Jul 23, 2011 | 04:36 PM
alex-300te's Avatar
1989 300te
is not in the abc reservoir is coming out of the stearing reservoir cap i did raise and lower the car bunch of times still spitting
Old Jul 23, 2011 | 08:05 PM
saintz's Avatar
GL450
The CL uses the same system for ABC and power steering. So that tank services both. I would say there is something wrong with the ABC, but that is odd that it just started out of the blue.
Old Jul 24, 2011 | 12:54 PM
alex-300te's Avatar
1989 300te
my independent mb shop, told me that i may have some air on the system to keep driving it, he top it off, got me a bottle of fluid, and send me on my marry way
he also say if dosent stop in a week he would bleed the system.
Old Jul 25, 2011 | 12:15 AM
awiner's Avatar
2003 CL55 AMG
Uses the same PUMP, however has two different tanks. One for the ABC and a smaller one for the power steering.
Old Jul 27, 2011 | 06:10 PM
alex-300te's Avatar
1989 300te
the tandem pump dosent pump the 2 reservoirs at same in / out, that's why is call a tandem pump 2 pumps in 1.
\The car is back to normal no spitting , keeping close eye on reservoir/
Old Aug 3, 2011 | 10:56 PM
alex-300te's Avatar
1989 300te
well after having the car at dealership and my independent shop, both agree air was on steering system, both recomend keep driving it for a while, to see if does bleed itself today just for the heck of it i remove the screw cap on reservoir and my filter was floating inside the tank, now what a bunch of idiots at the dealer and my independent, looking to change shop, or getting all the star system software to do the service my self, really pissed, i have software for my mack trucks, and im pretty good mechanic i work on my big rigs and i have a big building, Also the car got stuck in park yesterday my independent won't remove the lock ( wants to sell me a new shifter assy), and the dealer either, i have this lock removed on my 600, so i went ahead pull center console, got shifter out and remove the litte plastic trigger, job done, i dont have kids, and if some one opens a cl to take it, the plastic safety wont keep them from doing it.
Btw i drove the car at 110mph and not one drop of fluid come out of reservoir also is not foaming at all any more/
peace out
