Seat Control Module
Has anyone had this experience? If so, how did you fix it?
I am afraid to pull the module off of the door for fear of doing more damage.
What is the correct/safe way to remove this module from the door?
As always, Thanks for any help!
You need to take the A/C vent off the door panel. If you shine a flashlight in the vent you will see a captive Phillips screw that needs to be loosened. Once you have the A/C vent off, you will see a black plastic sliding mechanism to the forward side above the switch. Push it towards the rear of the car and the switch can be tilted out top first.
