Help. Wtb. Abc pump 2002 cl600
Part number : 002-466-60-01
Hey fellow w215 mb owners. I am really in need of this piece. I have had my car parked in my garage for over 6 months. I would appreciate if any one could help me locate this part. Thank you.
Ebay has new , used, remans take your pick.
What made you think sitting in the garage for 6 months caused it to need replacing? The valve blocks will allow the car to settle low over time causing the ABC don't drive light to come on. You can get the car to go to correct height by pressing the height switch to either one light or two or by putting the car in Drive after starting.
If you have had a leak or definite pump failure make sure the system gets flushed correctly so residual metal causes additional failures after replacing the pump.
Never been able to find the part on eBay. A link would be appreciated. It's been 6 months sitting because of the damage, my car also lost power steering which I have heard it is the same part. What is this about flushing the system? I did have a leak at one point but got the hose replaced.
You didn't answer who made the diagnosis of the pump being bad. There is a big sticky on the ABC issues with this car in this forum and one in the C215 section in benzworld you should read them.
http://cgi.ebay.com/ebaymotors/MERCE...item43a2049176
http://cgi.ebay.com/ebaymotors/Merce...item2eaac979ce
http://cgi.ebay.com/ebaymotors/USED-...item20b80fd6b5
http://cgi.ebay.com/ebaymotors/2000-...item5641cb50cc
