DIY Oil Change??
Do any of you have a DIY Oil Change for the W215?
----And yes, I know it will cost almost as much to have the dealer do it, but I like working on my car when I can.
Mityvac 7400
Filter is available on Amazon, Autohausaz.com, parts.com, or the dealer
Filter is on top of engine, not need to get on the ground.
You measure you oil using the buttons on the steering wheel (also instructed on the manual)
I drain the oil from the bottom. Jack up the car, remove the cover on the bottom. 13mm socket removes the oil plug.
Should be a simple job. I did mine too. The dealer promotion was actually $3 cheaper but I enjoy working [on the simple things] on the cars.
http://www.youtube.com/watch?v=C_4R0SFS-Q0
