CL-Class (W215) 2000-2006: CL 500, CL 600
Programa / Renntech V2 Module...Rear Raises When Should Lower
Old May 19, 2012 | 02:47 AM
OCKlasse's Avatar
MBworld Guru
04 CL55, 05 E500S4, 15 BMW i3 REx
Hello,
Has anyone installed the Programa/Renntech V2 lowering module with remote on his CL? My front works perfect, but the rear raises instead of lowers when you control it through the controller...any insight?
That's as low as a CL will go
Old May 19, 2012 | 11:15 AM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Its very common on the CL. You didn't get the proper instuctions. For the rear, the wiring is backwards. I had the same thing happen to me. I will have to see if I still have my instructions.
R.K.
Old May 19, 2012 | 12:57 PM
OCKlasse's Avatar
MBworld Guru
Thanks!
Old May 19, 2012 | 01:24 PM
radride's Avatar
On the 215 the rear sensor has to be swapped to + from the control unit.
On the black 8-pin connector in your instruction it says pull pin 2 and insert into pin 2 in the black connector and remove pin 5 and insert into pin 6 on the black connector. You have to swap those around. So now you have to take pin 2 and insert it into pin 6 in the black connector and take pin 5 and insert it into pin 2 in the black connector. Hopefully that makes sense. If you're still confused, call Renntech.
R.K.
Old May 19, 2012 | 01:35 PM
OCKlasse's Avatar
MBworld Guru
So all you're doing is swapping those two pins which are the first in the instructions to do? That's it?
What do you mean when you say the rear sensor has to swapped to + from the control unit? Is it just doing what you're saying above with swapping the pins or is this in addition to swapping the pins? Thanks!
Old May 19, 2012 | 01:47 PM
radride's Avatar
I believe that's what you're doing when you are swapping the pins.
R.K.
Old May 19, 2012 | 04:23 PM
radride's Avatar
I forgot that you also have to switch the number 4 yellow wire coming out of the module harness that goes to pin 2 into the car harness with the number 3 white wire coming out of the module harness that goes to pin 5. So pin 2 and 5 are also swapped on the car harness.
R.K.
Old May 19, 2012 | 10:43 PM
OCKlasse's Avatar
MBworld Guru
Thanks, R.K. I appreciate all of your help!
Old May 19, 2012 | 10:56 PM
radride's Avatar
Its been 9 months since I installed it on my car so my memory was a little foggy.
R.K.
Old May 23, 2012 | 05:34 PM
1995E320Cab's Avatar
2003 CL600 2005 745Li
Bump to get rid of the Vinyl guys post I'm so sick of seeing.
Old May 23, 2012 | 06:47 PM
radride's Avatar
Good call.
OCKLASSE, have you installed it yet?
R.K.
Old May 23, 2012 | 11:30 PM
OCKlasse's Avatar
MBworld Guru
Yes! Today as a matter of fact! Thank you! Worked perfectly...
Old May 23, 2012 | 11:31 PM
OCKlasse's Avatar
MBworld Guru
Old May 24, 2012 | 11:21 AM
radride's Avatar
So were my instructions correct the way I explained them?
R.K.
Old May 24, 2012 | 12:21 PM
OCKlasse's Avatar
MBworld Guru
Yeah...I was slightly confused, but looking at the supplied diagram helped. Thanks again!
Old May 24, 2012 | 12:25 PM
radride's Avatar
BTW you car looks hot!! Great job.
R.K.
Old May 24, 2012 | 02:58 PM
OCKlasse's Avatar
MBworld Guru
Thanks! Next are custom rear lower control arms to bring it down another inch...will also make my daily height more comfortable
Old May 24, 2012 | 03:16 PM
radride's Avatar
My wheels should be here next week. After I put them on, I might lower the car the final 5mm to the 2" complete drop final resting height. I won't be tucking but it will be nice and tight.
R.K.
Old May 24, 2012 | 03:57 PM
OCKlasse's Avatar
MBworld Guru
R.K.
