Bose Sound System
Tried searching the forum but nil help, I have a 2003 CL500, with bose sound system, i am looking for the specifications on this sound system.
Lately, i had to remove the car battery for some reason, installed it back, everything is back to normal, sync the windows and the sunroof.
But when i switched On the Head Unit (original) and played the CD, IT DOESN'T SOUND AS GOOD AS BEFORE, tried playing around with the sound settings but still, it doesn't sound the same.
Could anyone send me a diagram or specs of this system, or how to reset the system.
Thanx
I know that one of the biggest changes you can make under advanced settings is changing the 'effect' to 'Large' instead of 'Standard' or whatever it is
For my sound settings i use Bass - 10 Trebel - 7 and 'Large' and it sounds great
Another thing you could try is pulling/putting the fuse(s) for the command system, the fuse diagram should be in your trunk with the spare tire/tool kit
