Carlsson Wheels
I have a problem trying to find lug nuts that are the correct size/style for the rear wheels. The fronts fit with the stock nuts but on the rears when tightened the wheels are still loose because I run out of threading on the stock nut.
I was also given spacers (a ring that goes around the inside of the hub of the wheel so I don't rub) with the purchase...if that makes a difference with nuts.
Sorry I am new to this and I have a lot of research to do and it's very difficult to get in contact with Carlsson otherwise I wouldn't need to ask this. I was hoping anyone could shed some light on this for me.
Here is some pictures of them if needed.
R.K.
I have been looking for days and I can't find any info regarding these wheels. Also I'm not exactly sure how big the spacer is...sorry I'm new to all this, but do I just measure the distance from one end to the other?? Haha I can post pix of them when I get home if that would help?
Also would I rub if I just take the spacers off, because if I wouldn't than it would be much easier than going through the headache of finding longer bolts that will work for these wheels.
The spacer might be used due to clear the brakes or just to give it a more of a stanced look. I couldn't tell you. The offset determines where the wheels sit in the fender. Without knowing that, I can't even begin to tell you any more advise.
And yes you can get longer studs. Look on line or contact one of the venders here.
R.K.
R.K.
The only thing I could think of was that the original buyer bought them in a custom size or they are just wrong and it is indeed 10.5" rear and 8.5" front.
R.K.
By the way thank you very much for clearing some of this up for me!
