CL-Class (W215) 2000-2006: CL 500, CL 600
ABS BAS ESP Warnings lights on
Old Dec 1, 2012 | 09:45 AM
Jumbojim's Avatar
Mercedes CL500
These lights have appeared on my CL500 /2002, but at the same moment the Power Stearing became heavy. What connects them all?
Old Dec 1, 2012 | 02:00 PM
awiner's Avatar
2003 CL55 AMG
Again as with your EIS issue posted in the other thread, you need to diagnose with the workshop computer to see what the error is.
There are many speed sensors, ABS module, etc. that can cause this. It could be as simple as one of the wheel speed sensors.
As you stated when an error in these systems is detected all those systems are shut off as well as all speed sensitive systems such as power steering.
Old Dec 3, 2012 | 12:49 PM
rbanna's Avatar
2007 CL500 W216
Hi, Last time I had a flat tier, when i fixed the spare tire and its a 17" and my AMG rims are 18" that cause the BAS, ABS, ESP and gear limp mode to come on because the system detected a rime with different size and rotation is fixed, when I put back my original rim its all came back to normal again without resetting, have you had a flat tire recently??
Rami
Old Dec 4, 2012 | 05:06 AM
Jumbojim's Avatar
Mercedes CL500
Thanks rbanna, thats very interesting but does not apply in my case.
