CL-Class (W215) 2000-2006: CL 500, CL 600
Replace Door Handle (Keyless)
Old Dec 27, 2012 | 07:52 PM
slonar21's Avatar
CL600 2003
I need to replace my keyless door handle as the touch sensor is faulty, I thought it was pretty straight forward (remove handle via screws in the side of door) but in the WIS they say i need to remove the inside door panel.
Anyone ever changed just the handle, I think because it is keyless I need to remove the door pannel to plug the wire maybe.
I have attached the WIS
I am just replacing part #1, only the handle
So if anybody has any experience with this help would be appreciated, i really dont want to remove the inner door panel...
Old Dec 28, 2012 | 12:16 PM
awiner's Avatar
2003 CL55 AMG
I replaced both my handles last year due to the same issue.
You have to remove the inner door panel in order to gain access to the wiring harness plug. It is next to impossible to disconnect and reconnect the plug end with out doing this.
Old Dec 28, 2012 | 12:28 PM
slonar21's Avatar
CL600 2003
How difficult is the panel removal, looks very tedious from the WIS instructions
Old Dec 28, 2012 | 02:52 PM
awiner's Avatar
2003 CL55 AMG
Door panel removal isn't too bad. The instructions will walk you through it step by step.
Just make sure to not the orientation of all the pieces as you remove them such as the hook for the interior door handle and how it fits into the stirrup, etc.
Old Jan 14, 2013 | 11:44 AM
slonar21's Avatar
CL600 2003
Just finished and you absolutely need to remove the door panel
Here are good instructions for the door panel removal
http://www.benzworld.org/forums/w215...e-cl-door.html
