Co-driver side windows acting up
C215 CL55 AMG, W124 500E, W210 E430, W124 300E
Have a weird problem with my co-driver side windows. Sometime after closing the door, they do not close fully. Also i can't use the feature where a "full-push and let loose" of the button would close the window fully automatically, neither can i do it in reverse order.
Also on top of it, sometimes when im driving, opening the window and then want to fully close it again, it closes and immediately opens again to about 1/4th.
What is that?
What is that?
You need to re sync your windows. Basically roll your windows all the way up; release the button. Then roll your windows all the way down but don't engage the auto down, keep holding the down button until the window is all the way down. Once the window is all the way down, keep holding the down button for 3 secs then release. Then roll up the window but don't engage the auto up feature. Keep holding the button to roll up the windows until it reaches the top and keep holding it for another 3 secs. That window is now sync'd. Repeat for all 4 windows. Then try it by opening the window with the auto down and then auto up. It should close all the way.
Now if it works and then a couple of days later this happens again, it means your door harness is losing power due to age and fatigue. You will eventually have to have it replaced.
R.K.
R.K.
Thanks, it worked for the auto-close when opening/closing the doors, however still auto-up is not working at all, Auto-down does, but the window stops at 1/4 before fully down.
Do you think its the harness? Or is there a controller and sensors that monitor windows positions that might be shot?
Thanks for any further advice, as its annoying.
