De-laminating side windows
1 Post
2002 CL 500
My 2002 37k mile,garaged CL's dual pane door windows are slightly de-laminating around the edges. I am told it's common.
Two questions:
1. Would a slight bead of silicone around the window edges halt the de-lamination?
2.Anyone know what new side windows cost?![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
Two questions:
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
There is nothing to do that will fix or slow this process. Some windows get it worse than others.
Replacement windows will do the same thing over time. Its an issue that was never properly addressed nor fixed in future productions.
Mercedes did replace some of these side windows if this happened under the warranty period. The same issued happened again! As a matter of fact some of the new never installed units already had air bubbles starting to delaminate between the glass.
1 Post
05,cl65;33ford3wc.
My two Cls did this also a small amount, probably due to the flexing at the laminates edge. Years ago I did some lens bonding, there are adhesives made for this, however I wouldn't recommend any as this stressed area is not likely to react the we would want, remember the designed bond failed. If your willing to accept a possible failure masterbond produces bonding adhesives, also your otc remedies could work, a spot test for a while is prudent. I would not use super glue as it may be too rigid, if you do then a flexible version seems best to me.
1 Post
2002 CL 500
I was going to do a test spot with windshield repair resin. I was concerned it may cause the de-lamination to worsen.
One goal is to stop it. The other would be to fill it. I was thinking a smooth slight bead of silicone would prevent moisture from making it worse.
What do you think?
1 Post
05,cl65;33ford3wc.
Mine is not severe. Can't see it when the windows closed.
What do you think?
What do you think?
1 Post
2002 CL 500
Follow up
Sorry. No dice! There was NO penetration using windshield resin. And that stuff seeps in like penetrating oil. Must be an internal issue.
My advice. Leave it alone.
JRAZ305 (11-16-2021)
