Satelite antenna placement 2002 CL
Super Moderator
You can pull the panel off the inside of the trunk lid and mount the antenna there. The trunk is plastic and the signal will pass just fine.
Alternatively, if the antenna is a micro one you can mount inside the fresh air vent on the hood.
Super Moderator
Super Moderator
You can feed it in through the right side fuse/relay box. This will route into the vehicle just behind the glove compartment. You will see the area if you remove the glove compartment.
