CL-Class (W215) 2000-2006: CL 500, CL 600
Auto shifter surround...
Old May 14, 2013 | 02:43 PM
The_StiG_US's Avatar
Silver MY03 CL500 w/AMG Sport Pkg
Anyone know how to keep the automatic shifter surround bezel from moving? I have a MY'03 CL500 and the surround on it keeps pooping up and moving. It doesn't lock down. I had my local dealership try to fix it, but they had it stay down for about a day or two and it began popping back up. It is a bit annoying not what I call a good indicator of what a Merc should have for Fit and Finish. It seems to use two plastic loops to "snap" down, but the loops are either broken or have deformed and won't snap in anymore. Thought it would be a simple item to fix, but the electrical connector for Comfort or Sport shifting keeps me from just tinkering with it.
- Henry
Old May 14, 2013 | 03:49 PM
VII's Avatar
VII
2020 S560, 2014 SLK55 (Prev. 2016 S65, 2013 SLK350, 2008 CLS63, 2006 E350, 2006 CLS500, 2005 C230K)
Just put two tiny drops of high temp super glue. Remember you just want the smallest amount so that it will be easy to disassemble later if needed.
Old May 15, 2013 | 04:22 PM
Thanks for the advice, but was hoping for something that won't mar or cause a crack in the surround. If I just add a very tiny amount so that it can with some force come back apart, it might do, but I think that is what the dealership tried and did not last long. Also, not sure exactly where to put the glue so it won't hurt any electronics or the surround itself. Is this issue commonplace on our cars? Asking, because the design seems kinda shotty in comparison with the rest of the car. Maybe a design leftover from Chrysler?
Old May 15, 2013 | 04:33 PM
VII's Avatar
VII
My w203 had this problem after some transmission work at the dealer. They also attempted to repair but it did not last. For it to last you have to use appropiate adhesive (I used high temp super glue) and apply it to points of good contact.
The design is not very rugged and I imagine breaking or bending of the tabs is common if taken apart.
Other way to fix is to order a new part but trim pieces are usually very expensive.
Old May 18, 2013 | 12:30 AM
MiguelsC2CL's Avatar
2002 CL 500
It's caused my ham fisted techs. I have pulled mine many times and it retains its clamping force. You can find them on ebay all the time. About $50-$100
