CL-Class (W215) 2000-2006: CL 500, CL 600
Brake pedal dropping to the floor
Old Oct 29, 2013 | 07:47 PM
rockoosi1's Avatar
02 CL500
Brake pedal dropping to the floor...(possible brake booster)please help!!
Ok I've hit a brick wall on something that I thought was very simple. Long story short, my brake pedal won't hold? In other words once I press the brakes, the pedal slowly goes to the floor. I have changed the master cylinder (remanufactured BTW), bled all four corners and still nothing. I see no evidence of leaks so what am I missing?! Help!!
Could it be my brake booster? I can't seem to find much info at all on this one!!
Old Nov 7, 2013 | 09:53 AM
rockoosi1's Avatar
02 CL500
In case anyone reads this, it turned out to be my brake booster. I picked up one off of ebay with a master cylinder for $70.00 and now my problem appears to be solved. This is my 1st time ever having booster problems.
Old Nov 7, 2013 | 01:37 PM
awiner's Avatar
2003 CL55 AMG
On 10-19-13 I told you about the brake booster sometimes having issues here:
https://mbworld.org/forums/cl-class-...-cylinder.html
Old Nov 7, 2013 | 02:28 PM
rockoosi1's Avatar
02 CL500
The funny thing is I don't believe it was the seal like you mentioned. I think it was the actual booster itself. And to be honest I still haven't figured out a way to test it in the future. Oh well I'm just gald it appears to be fixed. Thanks as always for the help!
Old Nov 7, 2013 | 03:48 PM
awiner's Avatar
2003 CL55 AMG
Yes the boosters will go out form time to time internally. The seals I was referring to were the seals between the brake booster and the master cylinder.
At any rate, glad your problem is solved.
