CL-Class (W215) 2000-2006: CL 500, CL 600
Trying to install lowering module.
Old Nov 8, 2013 | 07:44 PM
TwinTurboTim's Avatar
2006 CL65
Trying to install my lowering module and on the first step it says remove pin 42 but that pin space is open and there is no pin in it. What am I doing wrong? I am looking at the ECU on the drivers side fuse box and I am looking at the inner ECU. I even looked in Star for the ECU location. Is a 2006 CL65 different?
Old Nov 8, 2013 | 08:03 PM
2006 CL65
I am even looking in Star Finder and it looks like the wiring is correct but I am so confused?!?!!?
Old Nov 8, 2013 | 11:23 PM
2006 CL65
Well I am guessing the ABC module isnt the inside one like Star says because more of the wire colors match up with the outside module. So I wired the Lowering module by pin position but they don't match up of what the pin color is supposed to be in Star. Guess we will see if it works.
Old Nov 10, 2013 | 05:16 AM
duhdenmark's Avatar
CL600
How are the instructions otherwise, does it look like a DIY project or does it require cutting wires, soldering etc?
David
Old Nov 10, 2013 | 10:37 AM
2006 CL65
No its a very easy install. Just depin some wires. You know mine would have been super easy but the wire colors just dont match what star says so that bugs me. If you dont look at star I guess it wouldnt matter because you install by pin location and not color of wire.
Old Nov 10, 2013 | 02:46 PM
awiner's Avatar
2003 CL55 AMG
What lowering module are you installing ?
Old Nov 11, 2013 | 01:49 AM
2006 CL65
Renntech V3
Old Nov 14, 2013 | 01:03 PM
radride's Avatar
2015 Challenger Hellcat, 2023 Ram 3500, 2005 E55 Wagon, 2019 GLC63s
Make sure to swap your rear wires. Other wise the rear will raise while the front will lower.
R.K.
Old Nov 15, 2013 | 12:48 PM
2006 CL65
See what does that mean to swap rear wires?
Old Nov 23, 2013 | 10:29 AM
Blkvip's Avatar
12' E559
take the LEFT wire and put to where the manual says to put the RIGHT. and put the RIGHT wire where the manual says to put the LEFT.
i have V2 had to do the same.
And the ecu you want is.. engine bay > drivers side > right outermost ecu (when looking straight into the engine bay). will look like this
Old Nov 23, 2013 | 10:34 AM
2006 CL65
I did figure out where the ECU is. The problem I been having now is it says the lowering module is connected but it never changes the voltages. I will switch the back wires but I know that wont fix the voltage not changing issue. I am guessing its a problem with my laptop software bit just haven't had time to mess with it.
