2003 w215 lowering via Star Diagnostics
Hi Everyone,
I recently purchased a C3 Diagnostic Scanner, i have read some post's stating that it is possible to lower the w215 through the C3.
I have tried to re-callibrate the level. after successfully re-calibration of the level.
i further calibrated the plunger travel sensor and the load adjustment.
The problem is - after all is done , if i cycle ( up and down ) the height control switch - it doesn't come back to the calibrated-level done by me .
Guys with C3 scanner , help me out, maybe the way i have been doing it is wrong .
thanks
thanks
Super Moderator
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Search the forum and you will find a vast amount of knowledge.
Start here: https://mbworld.org/forums/w211-amg/...ts-o-pics.html
Cliff Notes:
Lowering ABC via STAR has not been a good idea and rarly works. If it does the height difference in minimal.
On Airmatic setting inclantion angles work all the time and you get a great deal of lowering.
Cliff Notes:
