CL-Class (W215) 2000-2006: CL 500, CL 600
Rear wheel bearings
Old Nov 18, 2013 | 01:51 PM
rockoosi1's Avatar
02 CL500
Rear wheel bearings
I think I need to change mine (a little noisy IMO). Has anybody ever changed theirs? If so was it very difficult? I assume it just like most rear wheel drive, independent suspensioncars correct? This is another topic that I can't seem to find much info on. Thanksin advance!
Old Nov 22, 2013 | 02:32 AM
benz_addict's Avatar
V12TT
In my CL55 I changed the rear bearing it was noisy both sides. Common on these I find after a certain mileage. I got a shop to do mine back in the day. You will need a bearing press
Old Dec 2, 2013 | 04:02 AM
tusabes's Avatar
Mercedes
What kind of noise did it make ? I'm getting a squeal but don't know if its the rear brakes or bearings
Old Dec 3, 2013 | 11:18 AM
rockoosi1's Avatar
02 CL500
It’s like a constant whining noise that seems to be most noticeableup to about 45 mph. I plan on rotating the tires to see if the sound moves, Ijust haven't taken the time to do it yet.
Old Dec 3, 2013 | 05:04 PM
awiner's Avatar
2003 CL55 AMG
The rear brake pads do form a lip at the outer (bottom and top) edge from use that causes noises like that. You may want to take a look there as well.
