Curious as to the mechanical reason for ABC failure or non-failure?
Best info I have found on the system.
It's in German.So use your browsers translation feature.
http://www.exclusiv-automobile.de/ww..._Fahrwerk.html
What someone needs to develop is a diverter valve after the pump that loops the fluid back around when the system senses a low pressure condition. That way the pump would see no damage if a hose were to blow.
It's interesting that they are saying to replace the oil every 20k to 30k when MB lists no schedule. I've never understood why MB does not give change intervals on the fluid. I agree with what the site is saying but it doesn't address the need to proactively change the hoses before they fail. When one fails, it grenades the ABC pump if driven more than a short time. Blown hoses has got to be a bigger killer of pumps than long term contamination issues.
While I agree with maintenance , a fluid and filter change costs $700+ at the dealer . If you were doing this every 12-18000 miles as they recommend (every 20-30000 km) you'd have done it more than 5 times before the car hits 97000 miles and spent over $3500 just on fluid changes alone
