CL-Class (W215) 2000-2006: CL 500, CL 600
Problem with left side Headlight HID
Old Feb 13, 2014 | 03:10 PM
calgarycl55amg's Avatar
2003 CL55 AMG
I have a problem with the drivers side headlight, the driver side head light turns on but if you rev the engine or go for a drive it flickers and turns off eventually (within a 1min or 2min). I thought it may have been a bulb or ballast issue, so I switched(exchanged) the passenger and driver side bulbs but same problem persists. I have replaced the ballast with another used one. I had an old left side headlight with a damaged lens laying around from when I originally purchased the cl55 so I switched ballasts and still its doing the same thing.
Not sure if the higher engine rpms is causing a lose connection or overloading somethings????
FYI-Turn signal works, high beam and DRL works. Just the HID flickers and then dies shortly after running the car.
Anyone have a similar problem??
Any suggestions to resolve this problem?
