Keyless go question CL600
Is this true? I did not follow more into it at the dealer as I wanted to KNOW for sure what the facts are first. Whats the deal? thanks
http://www.ebay.co.uk/itm/Mercedes-B...item461451fe82
They are the same for W220 (S),W215(CL) and R230 (SL)
Hope that helps
I think i did it by entering the keyless module and then control unit adaptations.There as far back as i remember was a list of the keyless tracks which are synced.I think you will find either there or in the eis module.I have no idea why KG cards are easier to sync.Btw if your car is later than 2006-7 you will have the keyless function integrated in the smart key and that will be impossible to program by just star.Let me know if i can help further.
Have a read here :
http://bayhas.com/mercedes/cl215/con...key_assign.htm
Personally i've never done it this way.But it may work since its a MB service procedure.If you have already purchased a KG card,and there are no good indies in your area,you can try the above mentioned procedures - they will do no harm.If you're not successful,then getting to a good indy with a Star Machine should be able to do the job
Good luck
