::ECS Tuning:: W215 CL-Class Aluminum Shifter Lever Repair Kit
Click HERE to order or for more information.
Only $103.50*
An excellent replacement part for your W215 CL-Class, the URO aluminum shift lever upgrade eliminates the poorly designed plastic part supplied by Mercedes-Benz.
The URO kit it contains each part required for a complete shift lever repair,
including the rivets and shims necessary to rebuild the shifter assembly.
Note: Two styles of shift levers are differentiated by the width of the hinge pivot base (5mm or 11mm). The part is not defined by a specific year or chassis, so inspection of the existing plastic lever within the shifter may be necessary.
*Price subject to change.
