My passenger side rear window not working
The module going bad will typically result in no movement up or down from the window or windows. If your window looks to drop uncontrolled when you close the door, like the impact of door causes it to slightly move then it sounds like you have a regulator problem, if the window sounds to bind going up or abnormal problems it sounds like regulator problem.
If you want to get into it you can remove side panels and then remove the window motor from the regulator, now try and move the window up and down by hand to see if it moves freely, if you can not move it by hand with the motor removed then you clearly have a regulator problem
also my passenger front door window works but simply won't go up all the way at any time - it's always about a quarter inch down, as if it's always in the entry /exit mode
is that a module problem ?
any help would be much appreciated
I had tried swapping switches, replaced motor regulator, checked fuses and ordered a used right rear control module from Ebay ( defective )
Brought to deal for a flash upgrade, they did it and no go.
needed a new right rear control module, fixed. cost me $525 but happy door opens easily now
