CL-Class (W215) 2000-2006: CL 500, CL 600
DOOR CLOSED SENSOR PROBLEM
Old Oct 30, 2016 | 09:16 AM
pmercury's Avatar
member
CL
Exclamation DOOR CLOSED SENSOR PROBLEM
Hi
does anyone has repaired this:
when I close the car remotely some times the warning light blink fast speed and don't stop
I figured out that the car thinks a door is not well closed or so
so I slam the passenger door a little harder, redo close and its gone
also
passenger soft close turns off after a week or so
when that happens I just disconnect the the battery a minute and its gone
no leaks
I think that the "doors are closed" sensor is not in the right position or so
help is welcome
Old Oct 30, 2016 | 09:55 AM
Jack_88's Avatar
2018 C300
Are you sure there are no leaks? I have the same issue and I believe it's due to a failed soft close on the driver's side. I also noticed the lock goes down slower on that side. Hitting the lock button again when it starts blinking seems to stop the blinking. Also, if you disconnect the battery (or take out the fuse,) it resets the system when you reconnect it, and it takes a few times of the air pump struggling to get it closed to give up and shut down that feature again. Just because it works doesn't mean there is no leak.
Side note, I also drive a Kleeman tuned CL600. Mazel tov!
Old Oct 30, 2016 | 10:20 AM
pmercury's Avatar
member
CL
no leak, the door clics
but still then sometimes I have the lights blinking symptom sometimes
kleemann rocks
Old Oct 30, 2016 | 12:00 PM
Jack_88's Avatar
2018 C300
There can be a leak and the soft close still function. After so many times of the door working harder than it's supposed to, it shuts down and you have to pull the fuse or battery cable to reset it. Then the process starts over. Others have reported a similar timeline, ranging from 1-2 weeks.
Old Oct 31, 2016 | 02:45 AM
pmercury's Avatar
member
CL
anyone had this leaking problem, if it's a leak, and solved it ?
Old Oct 31, 2016 | 07:54 AM
Jack_88's Avatar
2018 C300
Sounds like it could be this issue. https://mbworld.org/forums/cl-class-...oft-close.html
Old Oct 31, 2016 | 01:09 PM
pmercury's Avatar
member
CL
really unsure that it is my cap
why not just a broken air line like I had once under my seat ?
Old Oct 31, 2016 | 01:43 PM
pmercury's Avatar
member
CL
I'm going to search where vacuum leaks
if that is the problem
Old Oct 31, 2016 | 06:38 PM
Jack_88's Avatar
2018 C300
Good plan, it just has to be a leak, the door is just the most common.
