CL-Class (W215) 2000-2006: CL 500, CL 600
Replace ABC with a coil overs on a 2001 S500
Old Apr 6, 2017 | 08:56 PM
lynnbrown's Avatar
2001 S500
My hydraulic pump for the ABC system is leaking and not holding up the front right side...we put a re-manufactured one in and it started clicking then blew a high pressure hose off the car..(this was after being shipped the wrong pump twice)!
My mechanic and I are both over it and I just want the car back on the road...he wants to replace the system with a coil over one and eliminate any further problems with hydraulic, what do you think?
In addition the power steering never had a problem or a failure, so do you think we can use the original pump for the steering portion??
Old Apr 7, 2017 | 03:36 AM
tusabes's Avatar
Mercedes
yes you can use the original abc punp
the yellow speed conversion is superior to the strutmasters conversion
Old Apr 7, 2017 | 12:01 PM
renault12ts's Avatar
W215 CL500 2005
To clarify, you can use the original pump for the steering...but you can't let the suspension side run dry.
