Vapor Canister
I've looked by the fuel pump and filter (dropped that small cover) and removed both rear wheel well inner linings. Cannot find it. Pulled out the entire rear trunk lining and can see the fuel tank clearly. Now I feel stupid enough so don't go flaming me more... I have an P0455 gross leak code and I've replaced the front solenoid.
AKA: ACTIVATED CHARCOAL FILTER.Part Number: 2204700559
Vapor Conister AKA ACTIVATED CHARCOAL FILTER.Part Number: 2204700559
The Job is now done and my only recommendation is to get that MB Tool ("Collar Hose Clamp Pliers Clic / Clic-R Type") about $15 on ebay or size yourself some hose clamps.
Be gentle with the lower nipples sliding the hose on and clamp the large top hose 1st (shown in picture) to the canister, then mount canister and finally clamp the large hose to the elbow fitting protruding out of the top wheel well from gas tank.
Im having some intermittent issues and wondering if it might be the vapor canister , but don't really know what the symptoms of a problem are . Anything you can help to explain what you noticed was amiss will help
