CL-Class (W215) 2000-2006: CL 500, CL 600
Bulb number for the two lights inside lights
Old May 21, 2017 | 12:40 AM
Grandcouper's Avatar
Cl500
One of these bulbs are out. So I was thinking of just changing both. I just can't find the number.
Old May 21, 2017 | 06:47 AM
pmercury's Avatar
member
CL
Old May 21, 2017 | 09:14 AM
tusabes's Avatar
Mercedes
You might want to get error free led to match the color of your headlights
The stock bulbs are yellow compared to the headlight
Old May 21, 2017 | 09:27 AM
Cl500
where can I get the "error free" LED? I didn't even consider it specifically because of the possible errors.
Old May 21, 2017 | 10:46 AM
AZN Optics's Avatar
SPONSOR/MBworld Guru
There are many designations for the wedge bulb you need. T10, 194, w5w, etc. If you want to go LEDs, you'll need canbus variant otherwise you'll trigger code and SAM will shut power to the socket.
We can help you out if interested. Shoot us a PM or email us directly at aznoptics@gmail.com.
Old May 21, 2017 | 11:41 AM
pmercury's Avatar
member
CL
I have tried several high quality leds for 6
they all burn after 2 month or give can errors
I paid up to 30$ each, latest 2017
for led backlight you need to slightly modify the bulb socket to be able to turn the socket into its wrong position the + to - and - to +
only on the RIGHT back side !
if you don't do this you'll get no lights at both sides, even with canerrorfree
Old May 21, 2017 | 08:34 PM
Cl500
I'll pm AZN to find out more about they're solution. Have any of you guys had success with the led lights or is everyone having the same issues as PMercury?
