No sound from radio try to locate the amp.
When I press the in dash eject I get a command nav disc. I also don't have volume control. I can't see the volume going up or down when turning the knob. Again not that I'd be able to hear it but I was thinking I'd at least be able to see the adjustments to the vol as I'm making them.
On another note, I finally ordered the seal for my tail light. Part number 2158260291in case anyone was looking for it. I pick it up for $17 on eBay. Now I just need to find a diy guide for removing the tail lamp.
You guys all rock on this forum by the way.
To test the speaker connections find the connector into the amp. Then use a small battery against each twisted pair. You should here a scratching at each speaker...if you don't the wires in the door jamb are broken.
If that is the case open the concertina cover in the door jamb. You will see two looms a small one and a large one. The small one is the speaker wires...open it and locate and fix the broken wires.
