CL-Class (W215) 2000-2006: CL 500, CL 600
Passenger window control
Old Aug 15, 2017 | 05:24 AM
David Lindon's Avatar
2005 CL500
Recently the passenger window switch is playing up, it will go down but when you press up the window will just go down even further. I can raise it from the driver's control. Is it just the switch? Are they easy to replace?
Old Aug 16, 2017 | 01:30 PM
ItalianJoe1's Avatar
2003 CL 600
Sounds like the switch has broken inside if it's still working well from the drivers side.
I believe you have to pull the door panel, but it shouldn't be too bad to change.
