CL-Class (W215) 2000-2006: CL 500, CL 600
help keyfob not recognized by car
Old Oct 20, 2017 | 01:27 AM
leemajors's Avatar
cls500
battery was died in car for about 4 months , when i went to jump battery off , couldn't get into truck , so we raised front passenger seat, and put a jump box on the red cable under the carpet
car came on , opened truck , as soon as i put cables on battery in back of car, the lights started flashing like the alarm was going off but no sound,
when i tried to turn ignition , ignition would not turn , key fob will not unlock doors , but will unlock/open trunk
says key not recognized any leads on this problem thx
car is a 2005 cl500 with 45000 miles
Old Oct 20, 2017 | 05:33 AM
tusabes's Avatar
Mercedes
First check the fuses in the passenger floor where you jumped it . They are the main fuses and often fail
if that doesn't fix it you're probably need a matching set of key shifter ignition switch and ecu from a donor car
all 4 parts must be changed because they are coded together as part of the anti theft system and they must come from
the same donor car
they sell matched sets on eBay for about $350
Old Oct 20, 2017 | 06:14 AM
Sojo40's Avatar
2006 CL600
Key fob
So is the key fob the original set and or is it a new key fob? The way I understand your post is it IS the original fob and the issue is the car has not started for 4 month and had dead battery which you, charged or changed?
If I have that correct you need to make sure the battery is new is the fob even if the concern it seems ok it's better to change it, a weak batt and act up at times.
So after batt change put the fob in the ignition and let it set there for a sec then turn to acc then to on just before the start position and let it set there for a bit. Sometimes the fob will act up and say not recognized and needs to reinitialize, if you are using one of the other key fobs that came with the car the set of 3 keys you have to do this so the ignition system initializes for that key.
BUT if you have new keys from another source not one of the original keys, the ignition turn key system has to be changed and the transmission program box inside the shifter has to be changed with the ones associated with the key fob.
If this the case you "might" be able to has STAR reprogram the keys and fob system...But I am not sure able that.
Good Luck my man...
Old Oct 20, 2017 | 01:03 PM
biker349's Avatar
cl600
Good Luck my man...
very interesting post. didn't know this was necessary.
