CL-Class (W215) 2000-2006: CL 500, CL 600
Inclination Values for 2006 CL65 AMG ABC system?
Old Nov 13, 2017 | 11:58 AM
isved's Avatar
2006 CL65 AMG
Hello all,
I have searched and searched and haven't been able to find specific values that worked for lowering the ABC system in a W215, specifically a CL65 AMG.
The advice I have gathered from searching was that value inputs have to be entered in small increments and the system should be recalibrated after each small change. That is understandable.
My goal is to lower the rear of the vehicle about 1-1.25 inches.
The car has a new pump and fluid, and all components seem to be in good and working shape. Passed the rodeo test a few times and is very quick while adjusting.
The main thing I am in need of are the inclination values that have worked for others while lowering the W215 chassis.
Any other pointers will also be appreciated!
Thank you in advance.
Old Nov 13, 2017 | 07:46 PM
ItalianJoe1's Avatar
2003 CL 600
When you go into the system, it should show the current saved values. Drop them by .5 degrees and see if that's where you want, go more or less as needed. Just make small changes, as you said. Doesn't take much, as it's measuring the angles at the inboard control arms.
