CL-Class (W215) 2000-2006: CL 500, CL 600
Cl600 inter cooler pump location?
Old Mar 13, 2018 | 08:14 PM
tusabes's Avatar
Mercedes
Had a weird thing happen , WAs leaving my car parked and running at the bank and then I heard a loud constant PSSH sound and white smoke started coming from the drivers front corner of the hood by the abc reservoir
I ran back to my car , turned it off and opened the hood . The PSSH sound stopped when I turned the car off. I Didn't see any abc Leaks, and abc still working fine upon restart . Didn't see any coolant Leaks, coolant level and temp normal upon restart . If it was a coolant leak the noise should have persisted even after turning the car off . But tho noise stopped immediately when I turned the car off . No obvious AC line Leaks and AC also worked fine on restart
also No PSSH noise returned upon restart ,and everything seems Normal!! I'm stumped !!
What could this possibly be ? Where is the intercoller pump located ? I am thinking maybe my intercoller pump or hoses failed ? (But I Checked intercoller fill cap and was still full ) car did seem a bit less powerful like I have less turbo boost now , but maybe that's in my head
any help appreciated !
Old Mar 15, 2018 | 09:04 PM
bng1959's Avatar
2017 S550 A217,2006 SL500,2002 CLK430
Not sure if you have checked this out... https://mbworld.org/forums/cl55-amg-...t-numbers.html
may not be what your talking about.
Old Mar 16, 2018 | 07:43 PM
pmercury's Avatar
member
CL
he has a V12, not a V8
Old Mar 16, 2018 | 07:46 PM
pmercury's Avatar
member
CL
the intercooler pump is located right side low under the car
remove the 1st plate under the car and the front plastic above the right wheel and you will see it
Old Mar 16, 2018 | 07:47 PM
pmercury's Avatar
member
CL
what smoke was it ? oil or coolant smell ?
Old Mar 16, 2018 | 07:50 PM
bng1959's Avatar
Old Mar 16, 2018 | 07:53 PM
pmercury's Avatar
member
CL
here how it looks like
https://mbworld.org/forums/m275-v12-...-included.html
Old Mar 17, 2018 | 03:12 AM
tusabes's Avatar
Mercedes
I wish I opened the hood while it was still running and making the noise and smoke , but when I ran back to the car the first thing I did was shut it down . I thought it might be unsafe to leave it running .
Then i opened the hood , looked around , didn't See any fluid , didn't smell or see any more smoke , then I turned the car on with the hood open and the noise and smoke was totally gone ! I've driven it three times and I still don't see or hear anything wrong , although power does seem down a bit from before , is it possible one of my turbos or wastegate or something broke ?
Old Mar 17, 2018 | 03:45 AM
pmercury's Avatar
member
CL
these turbos don't brake unless you use cheap oil
so it could be wastegates
you must locate the problem as this work is lowerering the front subframe and lifting the engine slightly
I have done it but didn't like that at all as if you go wrong you can get in big trouble
Old Mar 17, 2018 | 06:24 AM
pmercury's Avatar
member
CL
check your vacuum lines
Old Mar 17, 2018 | 06:25 AM
pmercury's Avatar
member
CL
Old Mar 17, 2018 | 06:27 AM
pmercury's Avatar
member
CL
