CL-Class (W215) 2000-2006: CL 500, CL 600
Trunk pump fluid refill
Old Mar 22, 2018 | 12:12 PM
Dominik Kuček's Avatar
W211 E55 AMG Kompressor
How to do it and what fluid to use?
Old Mar 22, 2018 | 01:58 PM
tusabes's Avatar
Mercedes
you can use regular AtF or pentosin chf11s
Remove the Battery Cover, and Right Rear Trunk Liner. The pump is under the battery
Lift the Pump Assy out of it's Foam Housing, and loosen the Jubilee Clip around the Plastic Reservoir, then get second pair of hands to hold it with Reservoir facing downwards, while you pull off the Plastic Reservoir.
Fill to the Line marked on the Plastic of the Reservoir, now carefully push it back on over the O Ring in the Body and tighten the Jubilee Clip ..............
